1crazylt1
07-27-2005, 09:33 PM
ok so i was changing my crank n got 2 of the 3 screws out..the 3rd one stripped..how do i get this bolt out i need out with this one..
Help!!1crazylt1 07-27-2005, 09:33 PM ok so i was changing my crank n got 2 of the 3 screws out..the 3rd one stripped..how do i get this bolt out i need out with this one.. Zero_to_69 07-27-2005, 10:41 PM Channel locks hammer on a smaller socket die grind the edge of the bolt Drill off the head, and use a strong plier to unscrew the 'stud' (if the bolt isn't counter sunk)...mabe even a reverse thread kit. P.S. Let me be the first to say, this thread is getting moved faster than a top fuel dragster at full throttle :cool: OldSStroker 07-27-2005, 11:12 PM Drag it over to SLP. IThey're in your neighborhood, right? :) Zero is correct. Try the specific forum for your engine. You'll probably get more responses there. Zero_to_69 07-27-2005, 11:48 PM Zero is correct. I don't see that much from you in this forum. I better enjoy the glory while it lasts. :D | ||
