ABS ring gear In Rear
SpeedDemon02SS
07-26-2005, 09:03 AM
Sorry, this is between drivetrain, and brakes post. My ABS INOP light no longer comes on. Not sure if the rear ABS are working. Had a loud bang in the rear a while ago. Is it possible that i broke the ABS ring gear?
LWillmann
07-26-2005, 09:21 AM
If that sensor isn't working right (like if that ring is broken) I would think the INOP light would come on and stay on.
SpeedDemon02SS
07-26-2005, 09:23 AM
what could cause the light not to come on anymore?
LWillmann
07-26-2005, 09:58 AM
burnt out bulb, or faultt ABS module or something like that?
1SlowFormula
07-26-2005, 11:22 AM
From you other post you say you have ABS and TCS, this means you have a 4 channel system so you don't have a reluctor ring in your diff, the sensors are at each of the rear wheels...
SpeedDemon02SS
07-26-2005, 11:29 AM
even if one of them is broken, shouldnt the other still work and make the ABS INOP light come on? how can i check for a bad module?
LWillmann
07-26-2005, 11:44 AM
Have you pulled the differential cover to see if you sheered a tooth off either the pinion or ring gear?
SpeedDemon02SS
07-26-2005, 11:46 AM
no. could that cause my problem?
the car still drives good...if i sheared a gear off, wouldnt that make it ride bad?
LWillmann
07-26-2005, 11:58 AM
It might still drive OK if it just sheared one tooth.
Pull the cover and look, that's the only way to be sure.
SpeedDemon02SS
07-26-2005, 12:03 PM
if i just leave it, do i run the risk of completely blowing the rear? I am replacing the rear very soon, and dont really want to take it all apart now.
LWillmann
07-26-2005, 12:34 PM
It'll take you 30 minutes and less than $20 to pull the cover and look, then replace the fluids.
1SlowFormula
07-26-2005, 12:58 PM
I am still trying to figure out why he feels his ABS INOP light should be on??? It doesn't come on untill there is a problem, unless you know there is a problem in the system and the light isn't coming on.
Why do you think it should be on??? Like I said in your other post ABS INOP = ABS INOPerative or ABS INOPerable, meaning it comes on when the system is broke...
rngilliland
07-26-2005, 02:57 PM
Are you talking about the low traction light. My abs inop light only comes on when I start the car. The low trac light comes on when the abs is activated.
SpeedDemon02SS
07-26-2005, 02:59 PM
i know...mine does too...but before the 'big bang' it used to come on when abs came on. low traction still comes on though...
