Camarocracy
07-26-2005, 02:03 AM
Already know about having them installed on a drive-on lift, I'm more concerned about things to watch out for?
Is there anything I should cover/move while having them welded-in? I think I read a post that said you should cover your fuel lines with something? :confused:
teke184
07-26-2005, 09:42 AM
just have them do short welds to keep the heat build up down so it doesn't affect the carpet inside.
romoranger
07-26-2005, 10:31 PM
prodyno installed mine in about 25 minutes today
still charged me 85 bucks :mad:
but at least they are on there
blown94
07-26-2005, 10:38 PM
Its super easy to pull the carpet up along the door edges, just remove the trim panel and peel your carpet up and stick a block of wood or something in there to hold the carpet up so it doesnt burn. I had a water bottle handy to spray down the floorpan as it got hot and I dampened the carpet a little. Other than that, yeah remove the clips for the fuel lines and hold them aside while theyre welding as you tend to come pretty close to them.
seawolf06
08-04-2005, 11:00 PM
85 bucks is awesome. cheapest i can find here is 140!
Camarocracy
08-05-2005, 02:44 AM
I just had them installed last week. My guy only charged $105 for installing the SFC's, the rear LCA's, and checked my plug wires to make sure they were all on tight [one was a little loose].
