What do I need to buy to use tunercat?
mattbailey
07-25-2005, 03:57 PM
I've looked at there website, but don't understand what all I have to buy from them.
I have a 94 Z.
Where can I get a cable and anything else that I will need. Thanks.
Tails
07-25-2005, 06:22 PM
From tunercat you going to want the Tuner package with the $EE definition file. Go here and scroll down to look for it:
http://tunercat.com/tnr_desc/do_tc.html
You can get a cable either from here:
http://akmcables.com/
or here:
http://www.wotelectronics.com/
Oh the search funtion here works great too...:)
Tails
Mean Green Z28
07-26-2005, 03:20 AM
I got the TC software with the $EE def. file from Tunercat and the OBD-I 94-95 USB interface cable from AKM .. they cost me about $200 total and well worth it!
mattbailey
07-26-2005, 01:33 PM
Thanks fellas, I'm looking to get a Tunercat setup in the next few months, I'd like to learn to tune my car. Where can I find info to know what everything does, what to cahnge, how much, ect... Thanks again for your help.
chevy94c
08-03-2005, 06:46 PM
I am about to order tunercat for my 94 Z28. So all i need is ODB1 USB/ALDL connector $90. Than the tuner programmer $69.95 and $ee ECM Definition File $19.95. Any help would be great
turbo_Z
08-03-2005, 11:44 PM
I believe when you buy the tuner you will get 1 def. file of your choice and then its $20 from then on for any additional def. files.
tjwong
08-04-2005, 01:30 AM
The one definition you get is for a $42 ECM which is an old truck ECM that was the original hack when the DIY EFI guys all got started up. So you need to purchase the $EE Definition from TC when you make the initial purchase of the tuner software package.
rngilliland
08-04-2005, 01:16 PM
That is exactly what I use on my 94 except I have the serial port cable.
67fso
08-06-2005, 03:54 PM
Save yourself some money and get a simple sturdy ALDL cable from:
http://www.aldlcable.com
You can buy either a 12 pin or 16 pin connector cable for the OBD1 setup for $40, and it shows up in your mailbox a few days later.
Dave88LX
09-04-2005, 07:32 PM
What exactly is an $EE def file? Why does it need to be purchased?
Bawls
09-05-2005, 07:40 AM
No No NO! absolutly do not buy this cable.
Go with a moates.net or akm cable. I've testedthis cable 94, and 95+ it does not work for programming. You'll be running a huge risk. I never got one successful read from that cable, bought a moates.net USB aldl cable works perfect.
Dave '97 Z28 M6
09-05-2005, 12:04 PM
Tunercat is a program that can be used with many different engines/cars. Tunercat uses these definition files to be able to properly read and program a specific engine. Each definition file will only work with 1 particular engine. In our case, we need the $EE file.
Dave88LX
09-05-2005, 01:07 PM
Oh I see. It won't affect the current tune I have on there from madwolf though right?
Dave '97 Z28 M6
09-08-2005, 02:02 AM
I haven't started playing with any of this tuning stuff yet... just dry research.
Tunercat can read and save your existing tune AFAIK. You can go back to that tune if you screw anything up. Someone please correct me if I'm mistaken.
Bawls
09-08-2005, 02:09 AM
yeah, just read PCM, save file as, then go about your tuning. Make sure to save your changes to a new file. not the original.
