roguedriver
07-24-2005, 11:54 PM
Whats the difference between mild steel and chromoly, say with a K-member for example. I would assume chromoly is stronger, but if so, how much stronger and how do weights compare? Thanks.
Ken R.
Ken R.
Difference between mild steel and chromoly?roguedriver 07-24-2005, 11:54 PM Whats the difference between mild steel and chromoly, say with a K-member for example. I would assume chromoly is stronger, but if so, how much stronger and how do weights compare? Thanks. Ken R. Injuneer 07-25-2005, 12:12 AM Generally, chrome moly is used to reduce weight. Because its stronger, you can use a thinner wall section in the tubing, reducing the weight, while keeping the strength the same. But chrome moly is difficult to weld correctly. roguedriver 07-25-2005, 08:15 PM Thanks for the info. Ken R. | ||
