Valkyn71
07-24-2005, 09:50 AM
Durring my tubular K-member/A-arm install i removed the front callipers/spindles and just let the brake lines drain out into a bucket and left them hang.
My car is non-traction control and has had the ABS INOP light on for pushing a year, and the Brake light i believe. I was reading in my Chilton's manual that inorder to bleed the ABS system you cannot have the ABS INOP light on. I have tryed changing the rear brake lights and checking the ground but no dice.
The brakes seem to work fine, but i have never locked them up too see if the ABS would pulse.
So am i going to have to take it to a dealer and have them read the ABS codes and have that fixed before i can bleed the abs/brakes?
