Can nitrous cause torque converter damage?
Old Jul 22, 2005 | 03:02 PM
LWillmann's Avatar
I realize this is both a nitrous and drivetrain question, but since it's mainly a nitrous question, I put it here.
I have noticed that when I drive my car around without using the nitrous, it stalls and shifts fine and the car feels just dandy.
When I start spraying the car, the shifts start to get softer, and the car starts to feel sloppy. The first run or two with the nitrous the car is OK, but after that, it gets soft and sloppy. It will stay that way for a while too.
After the car's had the night to sit and cool off, it goes back to shifting like it should, but the converter continues to feel looser than it used to.
The only temp reading I have access to for the transmission is in Autotap and I'm not sure if that's accurate or not.
I guess I need to know if the use of nitrous can cause any kind of permanent damage to my torque converter?
I'm running the stock stall with the stock transmission too.
I have 3.42 gears, a CAI, LT headers, y-pipe, cat-back exhaust and a 100HP wet shot. Car dynoed almost 290HP on motor alone recently.
Old Jul 25, 2005 | 07:33 AM
LWillmann's Avatar
Re: Can nitrous cause torque converter damage?
I'm going to post a copy of this in the Drivetrain forum to see if it gets any responses there.
Sorry for the double-post.
Old Jul 25, 2005 | 09:53 PM
IrocSS85's Avatar
I wouldnt think a 100 shot would do that. biger shots def. will, thats why they make antiballooning plates for nitrous convertors. so the conv. hold there intended shape through the instant torque nitrous provides. good question though hopefully people will chime in with their experience here. Ive never had a real "stock" convertor so I cant answer. but my Iroc had an aftermarket cheapo stall (stock type) and on a 125 shot didnt give me any problems at all the few times I did use it before I took the car apart.
chris
QuickSilver02
Apr 7, 2015 11:12 AM
F550maranello2
Apr 1, 2015 11:10 AM
armedtrigger
Feb 24, 2015 08:30 PM
StansZ28
Feb 19, 2015 07:39 AM
veryslowfbody
Aug 22, 2002 04:31 PM
