305 350 swap
riphc06
07-20-2005, 12:20 AM
does anyone know where i can find some information on a 305-350 swap? im also thinking of coverting from auto to manual trans. anything will help and be appreciated. thanks guys
klumb15
07-20-2005, 12:23 AM
thirdgen.org do a SEARCH tons of info out there, its a pretty straight forward swap...
dahaus
07-23-2005, 08:26 PM
If you are not using efi, then swap it. Everything bolts right together. If you are using efi, the there are other things to consider. (injectors,chips,etc) I have done these swaps, but I need a lot more information before I can help.
riphc06
07-25-2005, 12:28 AM
what other information would you need? haha because i am clueless....i appreciate the help....just let me know what you need to know....the existing 305 is TBI....thanks again just let me know
dahaus
07-25-2005, 12:49 AM
Do you want to keep your TBI? This will steer me in the right direction.
SLOW84TA
07-25-2005, 12:54 AM
well swaping the engine will be easy as everything is pretty much the same unless ur changing the intake system.
swaping to manual is easy if u just buy a full swap. I converted my 700R4 to a T-5. Check my cardomain for some pics. It was pretty easy. I did it in about 3/4 of a day. It'll be best to do it while your motor is out. Good luck
I found a how-to online and every worked out great for me.
riphc06
07-28-2005, 12:48 PM
well i will probably keep the TBI setup unless it would be easier to go with something else. i dont know what i would have to change in order to do a swap to a differant type of intake system. thanks alot
steve
riphc06
07-28-2005, 12:54 PM
where did u find the how to guide? is there any advice you could give me on this swap? i am just about ready to pull out the engine and the pics i saw of yours look almost identical with the parts i removed. anything will help. thanks alot
steve
dahaus
07-28-2005, 02:50 PM
If you are swapping motors and using the factory TBI setup. Things are still pretty easy. I am more of a TPI guy, but we did do this same swap on a friends car. He ordered a custom chip from Hypertech that was for the 350. This was about $400. Then he just transfrerred everything from the 305 to the 350.
Knowing what I know now, there are better ways to do it. The way my friend did it, works fine. But, there is a lot more performance out there. I have ran across TBI websites and forums that can give you some better advice. I can't think of them right now, but you can google them. I would google something like " 3rd gen TBI ". These guys can tell you what to do and what not to do. You will need all your specs on the 350, so a accurate suggestion can be made.
89_Irocz
07-29-2005, 01:32 AM
I had a 89 RS that came with a 305 tbi and it was changed to a 350 tbi...all you have to do is get a 350 tbi from a late 80's early 90's chevy truck and use the computer from the truck. The wiring is the same... And adding a 5 speed with it is also easy..
dahaus
07-29-2005, 02:10 AM
I was wondering if you could use the throttle body and computer out of a 350 pickup, but I wasn't going to suggest it. I had never seen it done and haven't researched. That is good info. to have.
89_Irocz
07-29-2005, 09:28 PM
Yes you can, I did... Its all the same wiring and bolt style... and edelbrock makes a tbi and intake that will make a few more horses that will hook right up without any mods...you can use there intake with your tbi or there's. Also you can add headers and a 100 shot nos and you will be hooked up nice... That's what I did and I'd mess up those LT1 boys... goodluck
