Starter
LoudmouthSS
07-19-2005, 11:12 PM
Can someone post a pic of their starter with all the wires connected.
Or explain where all the wires go on it...thanks
85_305
07-19-2005, 11:14 PM
:lol: Have fun man, I had the same EXACT problem at one time :D
Unfortunatly, it pissed me off so bad that I said "F*ck it" and had my friend do it.
LoudmouthSS
07-19-2005, 11:58 PM
god damn you lol
:D ....i looked in the haynes book....tells you absolutely jack ****
LesPaulGoth
07-20-2005, 12:09 AM
If you posted this about a week ago, I could tell you, but I remember a little. I wired mine the same way the stock was wired. If I'm correct...in the small terminal there is a yellow wire. All the rest (three wires) should go on the large terminal. On the large terminal there was a single red wire, a double wire with one connector (i believe it was red and black colored, and a thick black wire. I'm pretty sure thats what it was.
LoudmouthSS
07-20-2005, 01:24 AM
ok but which small terminal...mine is set up like this.... small o largeO smallo
there's two small terminals..
fade2blk500
07-20-2005, 06:02 AM
I want to say it's the bottom terminal if I recall correctly.
angel71rs
07-20-2005, 02:30 PM
The purple wire comes off the ignition switch and goes to the terminal (S terminal = switch) closest to the block. That's how it's been on Chevys for decades.
