confused327 07-19-2005, 11:21 AM im builing a 327 for a 3rd gen camaro(i did check the casting #'s). the only things i dont have are the heads the rest came with the car.
327ci
w.p. s/r torquer heads w/ 67 cc combustion chambers and 170 cc runners
cam: .480/.480 lift and adv duration of 302/302
edelbrock performer intake
headers
and a holley 600 carb
i was just wondering what everyone thought of it.
thanks
stale 07-19-2005, 03:59 PM What are you looking to get out of the 327? I'm assuming with that aggressive duration cam you're looking to rev the living hell out of the thing down the strip. That's probably going to put your peak power up in the 7000-8000rpm range. You're probably going to choke the car out before then though with that 600cfm carb.
Check out this article, these guys do a pretty serious street 327:
http://www.rodandcustommagazine.com/techarticles/74620/
angel71rs 07-19-2005, 04:26 PM Too much cam for the carb/intake/heads. You didn't list the duration @ .050" but from the advertised duration, sounds like an older style cam that would probably be around 230* @ .050. A newer design cam around 218* @ .050 would be a better match, especially in a car with an automatic and typical diff gear around 3.23-3.42.
If you do want to use as big a cam as you listed, you need more head/intake/carb/gear to make it work.
stale 07-19-2005, 04:34 PM You sure it's a 327? Could just be a 327 block with a 350 crank stuck in it. Some people always assume more displacement is better.
confused327 07-20-2005, 01:05 PM thanks for the replys. it is a 327 i mesured the stroke. the cam was free with the car and i did not know the power would be that high up there. this is supposed to be a street car. the cam is an older design i think because it is a crane cam and the specs came from the cam that is supposed to replace it. ive actually decided that the heads can wait, i may get some better ones later but i want to get the motor in the car. oh and the grind number is
h-302 if you would like check it out and maybe give a couple of suggestions for a better cam.
thanks for the good info
stale 07-20-2005, 01:07 PM Read that article I posted on the 327. They make a pretty grunty street motor out of old parts and a cam kit.
confused327 07-20-2005, 01:45 PM i did and really liked it but for the camel humps, there all over ebay but dont i need accesory holes. about the tfs heads i cant find any on summit that cheap.
stale 07-20-2005, 01:50 PM You don't really need the fuelies. I ran my 327 with a stock crank, stock rods, Sterling pistons, .020" over, 1.94/1.50 **** GM iron heads, single plenum intake, Holley 750, and some kinda high duration low lift cam. It put out about 350hp and rev'd up to 6500rpm. It as a little aggressive for street driving, but in my light ass car it was fine.
confused327 07-20-2005, 02:03 PM ok but my 327 has heads that have very small ports and valves (i saw bone stock 305 heads with bigger ports). for the cam i know roller is better but for the budget i am trying to keep what would be a good hyd. flat cam
stale 07-20-2005, 02:07 PM Look up the head castings on www.mortec.com. They're probably crappy, standard 1.94/1.50 heads just like every other Chevy engine. My 327 was just standard flat tappet hydraulic too. Totally met IHRA/NHRA stock class regulations :D
confused327 07-20-2005, 02:08 PM i have the engine apart . it has 1.74 valves
your camaro looks sweet :thumb:
stale 07-20-2005, 02:11 PM Oh, man, those are crap. Go junkyard a set of 1.94's for like $20. If you really want to get saucy, ream the 1.94's out to 2.02's and buy new valves.
confused327 07-20-2005, 02:12 PM i was tryin to say so. i have an offer for a set of rebuilt heads from a friend to trade the would be from a van with non-original heads im gonna check them out.
stale 07-20-2005, 02:16 PM Check 'em out. The 1.94 ****ty heads that everybody throws away are fine for street engines, especially in smaller displacement motors that don't suck as much air. Either that or pony up $900 for a set of Trick Flow heads and enjoy the power :D
Thanks about the Camaro. She's definitely one of my favorite cars.
confused327 07-20-2005, 02:19 PM maybe later on the trick flows but im gonna look at my buddys van later today
thanks for all the help. sweet car man sure wish i could fid a pre-restored 1st gen
angel71rs 07-20-2005, 02:34 PM i have the engine apart . it has 1.74 valves
Ah, good old powerpack heads no doubt. These were actually the hot tip.... in 1957. :D
confused327 07-20-2005, 03:45 PM These were actually the hot tip.... in 1957.
its a 1969??? :)
confused327 07-20-2005, 09:18 PM what would everyone think of a set of vortec heads with maybe a different cam????
stale 07-20-2005, 09:59 PM I've heard vortecs are the **** for a stock buildup. If you're not trying to hot rod that 327, the stock port sizes and flow rates would be great for a mild street motor. Drop those in with a cam like they used in that article I posted. Just get the flat tappet version with the same overlap and lift.
angel71rs 07-21-2005, 09:05 PM its a 1969??? :)
The Power Pack heads were used in hi perf sbcs in the 50's. In the 60s, the same design was used in low perf versions of 327s. I think they stopped using the Power Packs ~67-68, so if your 327 is a 69, won't have them. You can spot Power Packs at 20 paces due to the large triangle shape cast into front of head.
Vortec heads are killer low buck specials. Great flow. With a cam around 218-224*, would make excellent streetable power. Make camel hump heads look like crap. Check this chart out. Vortecs outflow the best 60s heads (186, 461, 462) at .400 - .500" lift:
http://users.erols.com/srweiss/tablehdc.htm#BBChevy
Ported 461s win out at .600, but that is meaningless in a street engine.
confused327 07-21-2005, 09:40 PM mine arent power packs, they dont have the triangle thing. the vortecs may be the next thing to come but i really want to just get the car on the road so i will probably just jet some junkyard 1.94's for now. thanks for the help eveyone!!!
