SpeedDemon02SS
07-17-2005, 10:21 PM
is it true that you can not re-surface cross drilled and slotted brake rotors?
Cross drilled rotorsSpeedDemon02SS 07-17-2005, 10:21 PM is it true that you can not re-surface cross drilled and slotted brake rotors? MyGreenBabyZ 07-17-2005, 11:08 PM no you can resurface them. I have had crossdrilled and slotted rotors resurfaced before. you just have to find someone that will do them. you end up having to remove VERY little material at a time. rollingstock 07-17-2005, 11:19 PM no you can resurface them. I have had crossdrilled and slotted rotors resurfaced before. you just have to find someone that will do them. you end up having to remove VERY little material at a time. *highjack* mygreen- can u pm me the spec.s on ur g1 crx?. maybe sum pics :bow:. i have a friend with a g1 crx with a d16a1(out of a g1 integra).. wouldnt mind seeing what ur set up is an whatnot. i used to have a g1 integra god i love that thing. i was in middle of a b16 swap. before i traded the motor and gave the car away.. :cry: i wanna get another one*end highjack* MyGreenBabyZ 07-17-2005, 11:38 PM sent you mail rollingstock. :D :cool: | ||
