600rwhp, Turbo charged, 2001 Pontiac Firehawk FOR SALE!!
bconn
07-17-2005, 05:52 PM
You are loooking at a 2001 Pontiac Trans-Am Firehawk. White w/black interior 5.7L V-8 LS1 w/ ram-air, 6spd, fully loaded, T-tops, keyless remote entry, factory alarm, 17 in chrome rims, traction control, Driver Air Bag, Anti-Lock Brakes, AM/FM Radio/CD changer, Cruise Control, Passenger Air Bag, Rear Window Defroster, Power Seats, Power Door Locks, Power Mirrors, Power Windows, Power Steering, Tilt Wheel.
This car has the following performance mods:
Custom built LS6 engine with the following parts; TEA 6.0 liter stage II CNC ported cylinder heads, Ferrea 2.055/1.600 stainless valves, Trend 5/16 chromemoly pushrods, titanium retainers, Ferrea double springs, Diamond dished pistons (built for boost), Eagle H-beam connecting rods, stock polished crank, Federal Mogul main bearings, Clevite connecting rod bearings, Total Seal rings, Roll Master double roller timing chain set, ported & prepped oil pump, Comp Cams custom hyd. Roller turbo cam, ARP main studs, ARP head bolts, LS6 intake, ported throttle body, 60lb/hr Motron fuel injectors, ASP balancer, ARP crank bolt, Aeromotive fuel rail w/ Aeromotive boost reference regulator. This engine has less than 1,000 miles on it.
Turbo Technology LS1 Street turbo kit:
LS1 Street Kit T76
Stainless manifold with 2.00 primary pipes / Tig welded / Argon purged / all flanges CNC cut for flatness and accuracy / 2.5” aluminized mandrel bent crossover / stainless V band flange connection and race gate flange / 3.00” mandrel bent aluminized down pipe (optional) / Innovative T76 Turbo charger / Turbonetics Race gate / Race gate stainless discharge pipe Spearco front mount intercooler with cast tanks ( over 1000 cfm ) / aluminized 2.5” compressor ducting / 3.00” inlet ducting with K&N filter / TTI compressor by-pass valve / silicone hose couplers with HD stainless clamps / gravity oil drain with CNC cut oil drain flange / all necessary hardware, fittings, & gaskets. Also has Godzilla blow-off valve. SMC alcohol injection kit is also on the car, along with a front mount air to air intercooler.
Transmission;
McCleod Twin Disk Clutch
Trans is new with less than 1,000 miles
B&M Ripper Shifter
Drivetrain;
Custom Chromemoly driveshaft
Moser 12 bolt rearend, 342:1 gear, 31 spline axles, Eaton posi, T/A girdle, 1350 yoke
HAL adjustable front coil overs
HAL adjustable rear shocks
BMR front springs
Eibach drag springs in rear
BMR adjustable torque arm
BMR tubular LCA’s
BMR adjustable panhard bar
BMR tubular front K-member
Fuel system;
Twin Bosch external fuel pumps
Aeromotive boost referenced fule regulator
Aeromotive Fuel rails
Motron 60lb/hr fuel injectors
-10 fuel line to the engine, -6 fuel line for return
Exhaust;
Custom bent 3”cat back exhaust system w/ Magnaflow stainless 3” tips, also has 3” custom y pipe.
Electronics;
Harlan 2 step box
Harlan shift light
Autometer Phantom gauges, (boost, fuel, water)
This car has made 600rwhp on pump gas with only 15lb’s of boost!!! It is capable of making a lot more power. It has gone 10.81 @ 132mph on Nitto tires. This is 100% a street car and is driven a lot in the summer.
This car is very clean, inside and out. No dent’s or scratches. Has never seen snow or rain, garage kept.
Here's the EBAY link:
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=4563011546#ebayphotohosting
sprayedtransam
07-17-2005, 08:43 PM
:eek:
bconn
07-18-2005, 08:34 AM
ttt,
thanks
aarong50
07-18-2005, 08:38 AM
Does the girl in pic 3 come with the car? JK vn car good luck hope you sell it.
Blackout96
07-18-2005, 11:50 PM
whats the price?...
what about the firehawk hood?
Owens Racing™
07-24-2005, 03:40 PM
whats the price?...
:confused: :shrug:
Looks Fishy huh dude!
YZF/LS1 Freak
07-24-2005, 04:47 PM
Yeah what about the hood?
Nice car, price seems a tad high but good luck with it.
bconn
07-29-2005, 11:27 AM
to the top
Owens Racing™
07-29-2005, 11:37 AM
to the top
How bout the hood chief!
bconn
08-01-2005, 08:21 AM
to the top
bconn
08-03-2005, 04:06 PM
car is number 238 build date 11/27/00
bconn
08-05-2005, 08:20 AM
to the top
Ryan94ZA4
08-06-2005, 05:35 PM
Yes, the hood. Reply about the hood. Why does this "Firehawk" have a "WS6" hood on it. As stated above, fishy. Fishy indeed.
Do you have the original or does this car just have Firehawk stickers and wheels?
Ryan
Ryan94ZA4
08-06-2005, 05:48 PM
If you can, snap a pic of the passenger door jamb which would show the SLP options (chrome wheels, trophy mat, possibly portfolio, etc) Then please explain the deal with the hood. Did you buy it this way and it had been wrecked or what??
Ryan
bconn
08-09-2005, 08:21 AM
bump ttt
bconn
08-10-2005, 12:08 PM
bump ttt
Birdman7389
08-10-2005, 02:12 PM
Shady.....not gonna answer the hood question huh?
97formulakid
08-10-2005, 06:26 PM
so hes not answering about the hood, the first post looks like he copy and pasted a lot of stuff, and his name is "bconn". dont sound to good to me
bconn
08-10-2005, 08:01 PM
Sorry guys, the hawk is real. Call SLP with the VIN number, they will confirm it. I just like the look of the WS6 hood better. The firehawk hood was just to plain for me.
Owens Racing™
08-10-2005, 08:13 PM
So you special ordered the Hawk with the WS6 hood?
bconn
08-11-2005, 08:29 AM
I sold the firehawk hood sorry like the raised hood
bconn
08-17-2005, 08:28 AM
bump ttt
bconn
08-18-2005, 11:13 AM
bump ttt
bconn
08-22-2005, 08:37 AM
bump ttt
bconn
08-23-2005, 06:47 PM
Price down to $26,000
bconn
08-24-2005, 02:06 PM
Ttt
bconn
08-25-2005, 10:51 AM
bump ttt
bconn
08-26-2005, 03:06 PM
bump ttt
bconn
08-28-2005, 04:53 PM
bump ttt
bconn
08-29-2005, 07:41 PM
bump ttt
bconn
08-31-2005, 09:49 AM
bump ttt
White_96_SS
09-02-2005, 12:21 AM
what about the firehawk spoiler?? I thought they all had L E D lights on the spoilers.. correct me if I am wrong..Bump for a nice ride
bconn
09-06-2005, 08:52 AM
I'm not sure about the tail light, i bought the car new and it came with that tail light.
bconn
09-09-2005, 12:57 PM
bump ttt
FutureZMan
09-09-2005, 01:34 PM
Everytime you dont directly answer a potential buyers question you are just wasting time bumping it, because no one is gonna buy your car if you keep dodging questions.
Take a pic of the inner door jam and then resume the selling of the car.
If not, quit bumping **** that aint gonna sell.
FutureZMan
09-09-2005, 01:52 PM
I was bored and had some minutes to kill, called SLP lol.
its a real firehawk bid with confidence.
GL in the sale man.
