Klortho
07-16-2005, 05:22 PM
Looking for a auto .bin file for tunercat to flash a manual PCM to work with a 700R4, does anyone have a base file I can use?
95 LT1 and 700R4Klortho 07-16-2005, 05:22 PM Looking for a auto .bin file for tunercat to flash a manual PCM to work with a 700R4, does anyone have a base file I can use? dkeers 07-17-2005, 11:16 PM Do you have a 700r4 (or 4l60) transmision or a 4l60e? If you are using the 700r4 (like I am) the pcm does not control the tranny. Your manual .bin should work with the 700r4 (I am not sure if you will need some speedo changes). If you actually have a 4l60e tranny, you will need a .bin from a n auto car. Dustin | ||
