weird smell
wakebordr2006
07-14-2005, 06:01 PM
after i drive my camaro somewhere, i always get this weird kind of smell from the engine area. it almost smells like burning rubber or something burning. i've tried opening the hood up to see if i could locate where its coming from but its almost impossible. has anyone else had this problem or does anyone have a clue?
Hedzilla
07-14-2005, 06:54 PM
check your spark plug wires, looms, etc, something is melting probably
99andMine
07-15-2005, 12:30 AM
Also, check your exhaust. Ive read where people run over a plastic bag and the up draft caused it to stick to the hot exhaust pipes. They further stated that it takes forever for it to simply melt off. Also, be sure to check your belt. Could have a pulley that decided it didnt want to turn as freely anymore.
transamtom
07-15-2005, 08:04 PM
Check the upper plenum on a 3.4L,mine has a small leak.
wakebordr2006
07-16-2005, 11:23 AM
where is the upper plenum located? and i have a 3.8L
transamtom
07-16-2005, 12:24 PM
Your intake is one piece
Loochy88
07-19-2005, 12:26 AM
sounds like uncatalyzed exhaust to me. im betting exhaust leak.
Tru2Chevy
07-19-2005, 01:47 PM
Nope, 3.8s have separate upper and lower sections....
- Justin
wakebordr2006
07-19-2005, 04:29 PM
i might want to add that if i'm running the A/C in the car, i get the same smell in the cold air
transamtom
07-20-2005, 07:58 AM
- Justin
Ooops,I should have looked at my manual first :o
transamtom
07-20-2005, 08:01 AM
As Loochy88 said,you probably have some type of exhaust leak,check the egr valve.
wakebordr2006
07-20-2005, 02:10 PM
egr valve?? what and where is that?
CamaroFan1718
07-20-2005, 03:47 PM
You notice oil dripping on the ground? Ive goten a weird oil buring smell and it also drips some oil now and again sounds like the same problem.
transamtom
07-20-2005, 06:04 PM
It recirculates exhaust gases to lower combustion temperature,reducing NOX emissisions.
Its on the drivers side of the engine on a 3.8L behind the power steering reservoir.
Theres a silver convoluted tube coming out of it,going to the intake manifold.
Edit for spelling :eek:
wakebordr2006
07-20-2005, 09:24 PM
YES!!! i do have small amounts of oil that drip down. i looked on the street where i normally park my car and i found a bunch of small oil spots. what needs to be fixed or replaced?
Loochy88
07-21-2005, 09:47 PM
youre going to need to find where the oil's leaking from to figure that one out.
