heavy 74 camaro, need help
camaro_dave
07-12-2005, 09:20 PM
ok i know there have been a few threads on this, searched and didn't find what i was looking for.
i know i have a pig of a car. its a 74 camaro thats been tubbed with chromolly cage aluminum heads....basic pro street set up. haven't weighed it yet but i bet its still over 3300 lbs.
has anyone cut up the floor and used like aluminum covered with carpet? i was thinking of trying that.
i want to keep the stock dash though
only have one seat. kirkey aluminum.
the doors are heavy...how would i get the surrpert thingy out of it?
what about lexan windows? does that reduce a lot of weight?
no front sway bar. and am going to be putting on light weight front brakes.
aluminum radiator?? thought about it.
half fiberglass hood. still have stock hinges and springs/ should i go pins/
all in all i just want it as light as possible without fiberglassing everything and i wanna keep my dash. any input would be sweet
Dave89IROC
07-12-2005, 09:32 PM
as long as you have good frame(tubing?) members onder the car, aluminum works fine for the floor
talos
07-13-2005, 12:17 AM
man i had the best link for you, but lost it somewhere... showed all the weights of every part on the car >< damn it
oh wellz...
well pulling the floor is a big job wouldn't really wanna undertake myself.. but consider fiberglass even though u did say u didn't want that stuff.
I had a 4" cowl bolt on hood, and the pin on version weighed about 15lbs lighter.. Fiberglass doors, fiberglass trunklid, tubliter(sp?)parts fiberglass fenders.. made right fiberglass or carben fiber can be made extremely strong
but that this is a racecar only? lexan isn't a bad idea eather
camaro_dave
i'm sure it has enough tubing under the car
XcYZ
07-13-2005, 10:19 AM
Make sure you check the NHRA rule book about the floor. If you remove it, it changes the requirements of the cage.
EDIT: Forgot to mention that the bumpers on that thing weigh a ton. A lift off fiberglass hood (and removing the hinges and latch assy) would be one of the quickest and easiest ways to lose some weight.
camaro_dave
07-13-2005, 04:04 PM
i don't want any fiberglass. already has an expensive paint job. but i would like fiberglass bumbers cause those aren't painted.
where would i find bumpers?
mw
07-13-2005, 06:30 PM
Back when I had my '76 I took all of the springs out of the front bumper and welded the tubes solid. Might could do it on the rear too. Luckly I never got in a head on crash. Not recommending this for a street car at all but for a striped out race car you could lose quit a bit of weight. Try at your own risk. :)
talos
07-13-2005, 11:20 PM
dunno if you would pass tech at a track with that...
ya replacing new paint is a pita, espesially if u just bought it :(
ive seen entire frontends that flip forward like a corvette... but once again thats fiberglass.. sometimes aluminum.
how about ur gastank? r u running a fuelcell? run a plastic or smaller tank depending on if its a street or a strip car... don't wanna run outta gas :D
camaro_dave
07-13-2005, 11:57 PM
i have an aluminum fuel cell.
if anything happens to the paint (heaven forbid) i will do a whole fiberglass front end. but hopefully that won't be for a few years
camaro_dave
07-14-2005, 01:44 AM
pulled a few things off and weighed em tonight....
front bumper 45lbs
inner fenders 30lbs
sway bar (already off but just weighed) 13lbs
radio and other misc crap 15lbs
total today is 103lbs!! not too bad.
lots more to come
XcYZ
07-14-2005, 08:45 AM
You could remove up to 200lbs by going to an aftermarket subframe like a Chris Alston, Martz, etc.
camaro_dave
07-14-2005, 01:57 PM
well i thought about doing a whole front end. there is a guy around where i live that does custom strut front ends with rack and pinion disk brakes etc..that would tie into my carge for ~ $2500. a guy i know did that and shaved like 230lbs off his camaro. i'll most likely do that if i do a fiberglass front end.
1996LT1NY
07-14-2005, 02:35 PM
Check this for idea's on where to loose weight from your second gen:
http://rcboat.com/Brian's%20stuff/camaro_database.htm
talos
07-14-2005, 05:15 PM
Have you pulled all that sound deading stuff from under the carpet?
hell the carpet alone weights a ton :(
talos
07-14-2005, 05:17 PM
NICE thats the site
camaro_dave
07-14-2005, 06:58 PM
ya good site. working on the carpet
jg95z28
07-15-2005, 11:15 AM
Unlimited Products carries fiberglass bumpers for your Camaro.
http://www.up22.com/camaro70.htm#top
camaro_dave
07-15-2005, 02:14 PM
sweet thanks
