brutalbird
07-12-2005, 12:45 PM
My 396 stroker has a reasonably streetable (I think) roller cam with 230/236 duration, 112 lsa, .520/.530 lift. I'm using 1.6:1 rockers so those numbers are slightly higher. At light engine loads the motor bucks to the point of being a drivability problem on the street - especially since it is a six speed. If I give it just a little gas or there is engine braking occurring the bucks stop. It revs fine, and the bucking seems more related to light engine load than rpm. If it is bucking at 1200 to say 1800 rpm all I have to do is touch the gas a bit and it stops. (This seems to be a common rpm when cruising on side streets)
My pcm was reprogrammed by Bryan Herter. It runs rich in the idle circuit 16, with split blms. I have triple checked everthing over the past year but can find no leaks, misfires or sticking valves. So is this just the nature of the cam? Are false lean at idle and surging under light load just something I must expect with a cam like this? :confused:
