What's up with the color of this exhaust valve
SABLT194
07-07-2005, 04:23 PM
Check out the odd color of #3 exhaust valve in the attached pic. Any clues as to whats going on?
Thanks,
Steve
http://home.comcast.net/~sbrough2/DSCN0203.JPG
dhirocz
07-07-2005, 07:42 PM
abnormal combustion temps maybe? I'd look at the injector on that cylinder out of a hunch, maybe it's leaking or something...but I dont really know either!
BlackDog
07-07-2005, 07:56 PM
Looks to me like a coolant leak. The pocket is slightly cleaner looking than the others.
Zero_to_69
07-07-2005, 08:00 PM
Just wondering if that particular valve has been replaced with a valve
made of a different composition than the rest?
I wouldn't suspect that has anything to do with coolant...being greenish...maybe? :think:
I'm interested in the results!
SStrokerAce
07-07-2005, 11:51 PM
Yeah that was my guess as well... if that valve is steel
MachinistOne
07-08-2005, 02:31 AM
I don't think it's coolant...the fire ring looks nice, and if water was in the chamber, there would be little white spots in there.
The intake valve looks a little blue, if you pull the intake valve and check for blueing on the stem, that will point to a lean condition or excessive heat in that cylinder...could be a poor injector.
Really it's something that I would need to look at in person, never tried to diagnose a problem based on a picture. I do see those single miss-colored valves occasionally, but I don't remember what I ruled as the cause during the VJE.
1racerdude
07-09-2005, 09:03 PM
Cyl is to hot for some reason.
