Mikael
10-20-2002, 10:05 PM
I was wondering, since there are a few of you doing LT1 swaps, are they interchangable? I know the spring rates are different, but what about the actual fit?
Mike
Mike
V6 vs V8 springs Interchangeable???Mikael 10-20-2002, 10:05 PM I was wondering, since there are a few of you doing LT1 swaps, are they interchangable? I know the spring rates are different, but what about the actual fit? Mike stars1010 10-20-2002, 11:40 PM I cant say from experience, but as far as I know they are totally interchangeable. Should be same exact fit. atl2001 10-21-2002, 01:33 AM ill let you know when i put mine on, i have been told they fit , i have a set , just arent on yet MustangEater82 10-21-2002, 10:19 AM They ar totally interchangeable, same withabout every other suspension part. thing is they will raise the front of the car an inch or two do to the lighter weight of a v6. Mikael 10-21-2002, 11:51 AM I actually have a V8, but i couldn't get a response in LT1 tech. You guys are alright. Mike stagen 10-24-2002, 11:19 PM Completely inter-changeable with no modifications needed to be done. In fact you'll see some fo the LT1 guys running rear V6 springs at the track. FilledWithFurySS 10-26-2002, 10:39 PM yes they are interchangable... Good luck in the swap!! ~Mike blue95 10-27-2002, 01:40 AM yup they will go and they are a small upgrade for our cars(depending on the year)....check out this page for some specs on them http://angelfire.com/my/fastcar/suspension.html | ||
