tywe
07-05-2005, 11:16 PM
What does it mean when your spark plugs are black around the base, but the metal tip is white? Here are some pics of the plugs:
http://www.phastnet.com/users/shawn/images/ngk-1.jpg
http://www.phastnet.com/users/shawn/images/ngk-2.jpg
http://www.phastnet.com/users/shawn/images/ngk-3.jpg
http://www.phastnet.com/users/shawn/images/autolite-1.jpg
http://www.phastnet.com/users/shawn/images/autolite-2.jpg
The NGK FR5 plug had about 5-6k miles on it, while the Autolite 3924 only has about 100-200 miles on it. My guess is that there is enough fuel (the black part), but the temperature at the tip is too high causing it to turn white? If that's the case, should I try a colder plug?
Some background info, in case it helps:
94 Z28 T56
383 c.i. (11.25:1 scr)
62cc Trickflow LT1 heads
230/242 (.510/.540) 114lsa comp cam
1.6 roller rockers
Comp 'R' lifters
Jet-hot long tube headers
etc
The car has been running good, it just has a random miss at low rpms that I can't seem to figure out, and it will also occasionally backfire out the intake if I blip the throttle from an idle. But otherwise, it runs very strong and smooth throughout the rpm range.
Thanks in advance for any help!
Shawn
94 Z28 T56
1.6 roller rockers
Comp 'R' lifters
etc
Shawn
