ChrisUlrich
07-05-2005, 02:13 PM
Ported and Polished with the XE 284 cam... whats you're take on this setup? Looking for a nasty lope/rumble?
LT's, x pipe, and... not sure of the catback
Fuelie HeadsChrisUlrich 07-05-2005, 02:13 PM Ported and Polished with the XE 284 cam... whats you're take on this setup? Looking for a nasty lope/rumble? LT's, x pipe, and... not sure of the catback Tru2Chevy 07-06-2005, 12:13 PM That cam should give you a very nice sounding idle. I have the XE274, and it sounds pretty damn nice all warmed up and idling at 600RPM :D - Justin LameRandomName 07-06-2005, 02:19 PM Well, I've run a SIMILAR setup and I'll tell you that you will enjoy the combo. Nice lope and a strong puller up through the 6000+ range. Or at least the 280H cam I used was... that cam should actually be a little bit better. However, head technology has come a long way and you can do better than Fuelie heads. At the very least, send those heads to a porter with a good rep to let him do his thing. You're probably also going to want to mill them to reduce the combustion chamber size, even if it means running a dished piston; and if you're going to mill them then you may as well angle mill them. Of course, now you're starting to spend some money, but I thought you'd like to know. 1quikZ 07-06-2005, 02:32 PM I agree with "random" Id go for a bit newer head or atleast get them P&P, why not go with something like L98's or voretc heads? XcYZ 07-06-2005, 03:24 PM FWIW, the X-pipe will mellow out the lope at idle. ChrisUlrich 07-06-2005, 10:17 PM FWIW, the X-pipe will mellow out the lope at idle. Really? Mellow out the lope? Getting the Fuelie heads P&P for $250 from a good friend... thats why i'm going with them. Plus, the funds aren't there for aftermarket ones. XcYZ 07-07-2005, 09:33 AM Really? Mellow out the lope? Yep, with one of my motors, I went from an H-pipe to an X-pipe, and the difference in how much less aggressive the idle sounded was dramatic. The headers and Flowmasters were the same, all the was changed was the swap from the H to the X. While it mellowed out the idle considerably, it sounded great at WOT. Tru2Chevy 07-07-2005, 11:30 AM Here is a short video of my 400 with the XE 274 (open headers): http://www.njfboa.org/JustinImages/400.MOV Quality isn't great, but it will give you an idea..... - Justin ChrisUlrich 07-07-2005, 08:59 PM Here is a short video of my 400 with the XE 274 (open headers): http://www.njfboa.org/JustinImages/400.MOV Quality isn't great, but it will give you an idea..... - Justin What motor is that? I should of mentioned this is a 327 1quikZ 07-07-2005, 10:36 PM Wow, that is one lopey cam:D Tru2Chevy 07-11-2005, 02:15 PM What motor is that? I should of mentioned this is a 327 That is the XE 274 on a 400sbc with mildly ported vette L98s (more detail in the sig) The XE 284 in a 327 will prolly have a lot more lope, as cubic inches tend to eat up a bit of lope. A buddy of mine had the XE 274 in a 350 with edelbrock performer heads in his '77 vette, and it sounded pretty nice through shorty headers and a crap exhaust with a pair of 40 series flowies on it. - Justin | ||
