Need Valvetrain Help. Located in Eastern Ohio.
usa1racing
07-04-2005, 01:57 AM
I am building a new motor for my Camaro, and need to check valve-to-piston clearance with TRW domed pistons. I also need to check pushrod length. I need 1 rocker arm and a checking pushrod. I want to use 1.6 rocker arms, and I can use either a 3/8" or 7/16" stud. If someone can help me out by letting me borrow, or meeting me here in Ohio to check the clearances and pushrod length, I'd really appreciate it.
Does anyone have expeirience with these pistons? They're part # 2304, with a 0.125" dome installed 0.023 in the hole. I plan to use a thicker head gasket. The cam is Comp Cams part #12-622-9, and it has 0.500/0.510" lift with 1.5 rockers. With 1.6 rockers, it would be 0.544/0.533".
Next question is about rockers. I'm considering Harland Sharp, Summit, and Scorpion. I know the Harland Sharp's are good. Anyone have ideas on the others, or another brand I should be looking at?
