anasazi
06-29-2005, 11:29 PM
so i'm coming back tonight down a fast road and i put it in "D" for some high speed fun. well when it came time for the fun to end i went to push it back into OD but instead accidentally tapped the shifter while my hand was going back and shifted into 2.
to my surprise it shifted :eek: :eek:
i quickly shifted back into OD and all was good. RPM's didn't go past redline but it sure did scare the crap out of me.
CrabhartZ28
06-29-2005, 11:39 PM
it'll shift into 1st if you tell it to. these late model A4s will stay in 1st and will stay in 2nd/start in 2nd if you put the shifter in that position.
MISOMWS6
06-30-2005, 06:41 PM
Yeah, I guess with 273's it could be right around there, with my 323's it shifts into 3rd at WOT around 85mph.
slowpoke96z28
07-01-2005, 05:35 AM
it will shift into second anytime you select that gear.(and it'll tear you engine up, too, if you let it)
most 4L60E strategies will command an upshift to second if you try to select first at too high a speed. but it will give you second whenever.
CrabhartZ28
07-02-2005, 01:43 AM
Is that right? I don't want to test it obviously, but i'd sure hope it would have some sort of fail safe for that situation.
slowpoke96z28
07-02-2005, 02:02 AM
no fail safe for second gear, bro.
CrabhartZ28
07-02-2005, 02:08 AM
I know it doesn't, but i'd hope it would have one for first, which is what you said correct?
slowpoke96z28
07-02-2005, 02:29 AM
the PCM will not allow 1st gear form manual 2nd unless the car is < 30 to 35 mph. if its faster than 35, the PCM will hold second gear instead, even though the shifter is in first.
CamaroSS30thAnn
07-02-2005, 01:35 PM
my car with 3.23s will shift 1-2 at 35 2-3 at 77 if u have 2.73s its possible but im not sure
slowpoke96z28
07-02-2005, 03:06 PM
we are discussing WOT downshifts not upshifts. those upshifts sound about right though.
