wicked_95z
06-29-2005, 12:01 PM
I have a mallory hyfire VI and was looking at their map sensor for boost referenced timing. It looks like it mounts where the stock one does on the manifold. If so, can I eliminate the stock one or do I have to mount it somewhere else. Thanks
carnutz
06-29-2005, 02:10 PM
You need to run a vaccume line to it, you cannot replace the stock senser with it because then where does the ECM get its MAP reading?
wicked_95z
06-29-2005, 06:57 PM
So I just mount the sensor anywhere and then run the vacuum line off of one of the ports on the intake. Cool Thanks
