Help!!!!!
Old Jun 24, 2005 | 08:57 PM
6shot38's Avatar
Help!!!!!
ok as some of you know im in the process of doing an ls1 engine swap
my car 1998 camaro v6
donor car 1998 z28 vert
ok today i looked at the fuse box on both the v6 and the v8
the v8 has more fueses on the v6 those are dead spaces
what do i do willk this affect anything i herd that on the v8 the coil packs have 2 fuses and the v6 1 how do i remidy this wire situation
please help if you can
and also on the left hand side faceing the engine the throttle cable from the gas pedal goes into a box and comes from there and goes to the tb
it has 2 wires connected to it my v6 does not have a wire there.....
and last someone mentioned that i can use my gas take if i get a t bar and run the return line back into the main line is that true????????? please help if you can
Old Jun 25, 2005 | 08:16 AM
Hedzilla's Avatar
Re: Help!!!!!
best i can tell you is to look at magnus's site. he did a walkthrough on the swap.
