G. McDonald
06-20-2005, 11:08 AM
This is probably a dumb question, but is regular rubber fuel line compatible with brake fluid or will the rubber degenerate?
I need to use some rubber line to go between my clutch reservoir and my clutch master cylinder, so the fluid will not be under pressure, I just need rubber line of the right size that is compatible with brake fluid. I can't find any hose of this sort that is marked as being compatible with brake fluid.
Thanks for the input.
