1crazylt1
06-19-2005, 12:15 AM
ok..well wen i go to turn my car on it will just crank but wont start..it sounds like the motor is not gettin gas..but thats my opinon..does anyone think i need a fuel pump?let me kno..thanks
-1994 chevy z28 camaro-
Bow94z
06-19-2005, 12:30 AM
yea most likly fuel pump, its cranks but just nothing right??? how many miles are on the car? Check your coil too before you go and do a fuel pump change
Kris93/95Z28
06-19-2005, 04:01 AM
Do the basics before attempting to fix the fuel pump. First, do you hear the pump kick on when the the key is turned to on position? Assuming that checks out, how old is the fuel filter?
Kataklysm
06-19-2005, 11:02 AM
Definitly make sure it either isn't getting fuel or spark before you go buying parts.
1crazylt1
06-19-2005, 02:27 PM
ok like 2 weeks ago brang it to the shop for boggin out..they changed the plugs,wires,fuel filter and disturbutor..the car has 110,00 miles on it. yes i do hear the fuel pump turn on wen u turn the key
OBE1 95Z28
06-19-2005, 05:52 PM
Attach a fuel pressure gauge to the Schrader valve on the fuel rails and check your fuel pressure. Fuel pressure should come up to around 36 psi and slowly decline after the pump stops (2 second time out). If the pressure drops quickly, the check valve in the fuel pump is shot and the fuel pump will need to be replaced.
