Kris93/95Z28
06-18-2005, 02:58 AM
My car has had an issue for the last week were it may/may not start. It seemed the battery wasn't allowing the starter to crank enough. So tonight it wouldn't start, that was the final straw.
Anyway, I got a new battery, and was removing the old battery and the Positive terminal BROKE OFF :mad: I look at the tray and area around it, and it looks like its been leaking a while. I got the hose out and sprayed the areas for 5 or so minutes, then took a rag, and wiped up as much as possible.
The question is there is some discoloration in the paint right by the two coolant hoses that come off the water pump, and there are some areas that are discolored on the coolant hoses mentioned above.
Should I be worried? Is there something more I should do? Please let me know ASAP. I am worried about the paint, and the hoses pretty bad right now.
