ACE1252
06-18-2005, 01:40 AM
I just wanted to see how many here have purchased the rebuilt power steering rack from Autozone. Have you had any problems with it? I have some slop in mine and I think I'm going to have to replace it. It costs only $135 and I'm sure that will beat the heck out of what GM will want for one. Comments? Anybody done this yet? Thx!
RocCityZman
06-18-2005, 08:17 AM
I ordered one and it came within a few days, then I took it back because I decided I was going to wait until after the summer. It looked just fine and had the inner tie rods already mounted. I will probably buy one of these again when I decide to actually fix this problem (same thing, slack in the rack).
n2ceptor
06-18-2005, 11:02 AM
There are two different rack offered... Be sure to get the Sport Suspension one..
RocCityZman
06-18-2005, 01:30 PM
Good point. When you order it will ask you which type of gear you want. Double check the RPO code on the order form with what's in your car. You will find it on the RPO sticker in your glove box.
Lower
06-18-2005, 03:10 PM
So this unit comes with the inner tie rods for only $135?
I guess I won't be replacing the inner tie rods at $30 each, and instead will opt for replacing the whole rack. Sounds like a good deal!
ACE1252
06-18-2005, 05:41 PM
The sticker should also be on the end of the driver's side door. If it has not peeled off.
OBE1 95Z28
06-19-2005, 05:57 PM
I've got about 2,000 miles on my rebuilt rack I got from autopartsonline.com. It was $130 and also came with the inner tie rods and new boots. Looks identical to the stock GM unit and works great.
RocCityZman
06-20-2005, 09:56 AM
Yup...and I'm pretty sure you can take the core back to the nearest Autozone store instead of shipping it back. Like I said, I ended up returning mine so I could work on another project and I took it to the store and got full credit back.
