JZ 97 SS 1500
06-17-2005, 03:11 PM
Well I have been so busy that I haven't had time to post squat lately, but figured some of you guys have been wanting pictures of the SS. Well here they are below.... For those that don't know the specs...here they are...
Stroked and Bored 383 LT1/4
Eagle Forged crank
6.0 Eagle H beam rods
Custom HD JE pistons
HD JE rings
Clevite race HD race bearings
Yella Terra 1.6RR's
CC 987-16 valve springs
AFR 195cc LT4 heads ported to ~205cc, 2.05/1.60 valves
CC custom grind, 230/230 .544/.544 lift on a 114LS
Block is a 4 bolt main, studded and all ARP hardware
8.5 compression ratio
Felpro head gaskets
Fully ported LT4 intake manifold
BBK 58MM T.B.
Meziere Electric water pump
Kit...
PTK Custom Gen1 LT1 Outlaw kit
1 3/4" 4 into 1 headers fully coated
2 1/2" crossover pipe with flex section
Turbosmart Billet 38mm Wastegate
Custom Water-to-Air Intercooler
Teel Marine pump for Intercooler
V-Band Clamps and Ball Joints
Twin Tial 50mm BOV's
4" Inlet pipe with 8" K&N cone filter
All turbo piping done in 3" and fully coated
Air to Air heat exchanger mounted in nose
Dual Spal 10" pusher fans
Precision Mid-Frame PTE-88 mm turbo with .96 A/R
3" downpipe for street with Electric cutout on downpipe
Custom 4" downpipe with dump for track use.
Snow Performance custom kit for Meth and Nitromethane injection
Computer...
FAST Engine Management with wideband
3 Bar Map sensor
LTCC with LS1 coil system
TurboSmart E-boost 2
Autometer EGT guage and probes in cylinders 7&8
Innovative gauge wideband kit
Drivetrain...
Lightweight Dynabatt Dry Call battery
Hypertech 160 thermostat
Lakewood Control arms
Lakewood Adjustable Panhard Rod
Taylor 8mm wires
Autometer Monster Tach w/i ShiftLite
McLeod Street Twin performance Clutch
BMR's Trac-Pac includes :Adj. Torque Arm, Subframe connectors and Crossmember
Moser Engineering rear with 35 spline axles, 3.50 gear and Detroit locker
Steve Spohn LCA lowering brackets
Custom 3" AL driveshaft
Polished ZR1 rims- 17X9 275/40 front/17X11 315/35 rear
Fuel system....
Tapped tank
-10AN feed line
SX regulator, boost sensitive
Dual Walbro parallel Inline pumps with custom billet aluminum Y-blocks
83 lbs Sieman Deka Injectors
Weldon Fuel filter
Modified LT1 Fuel rails with dual -6AN feeds
-6AN return line
Pic of SS and bird (http://forcedinductions.com/images/SS/SSWS6b.jpg)
Rear shot SS (http://forcedinductions.com/images/SS/SSrearcolor.jpg)
Interior and Gauges (http://forcedinductions.com/images/SS/interiorSS.jpg)
Nose cutout (http://forcedinductions.com/images/SS/nose.jpg)
Another rear shot for the mustang crowd (http://forcedinductions.com/images/SS/rearshot.JPG)
Jose
Eagle Forged crank
HD JE rings
Yella Terra 1.6RR's
Felpro head gaskets
BBK 58MM T.B.
Kit...
Computer...
3 Bar Map sensor
Drivetrain...
Taylor 8mm wires
Fuel system....
Tapped tank
-10AN feed line
Weldon Fuel filter
-6AN return line
Jose
