Headlight motor.
Old Jun 16, 2005 | 12:19 PM
SpoolinV8ETR's Avatar
Headlight motor.
I have a 94 Formula. When you turn the lights off the driver side keeps going and going till it finally stops. Both lights go up and down just fine. The motor just keeps running.
Is there anyway to make it to the head lights to popup unless the headlights are on? looks weird with the lights up and only the parking lights on ya know?
Old Jun 16, 2005 | 07:12 PM
Kataklysm's Avatar
Re: Headlight motor.
Your headlights should be down all the time unless the lights are on...Your descibing the symptoms of a stripped headlight motor gear...just buy a brass gear off ebay or someone here and put it in.
Old Jun 16, 2005 | 10:30 PM
There down all the time till i turn on either the parking lights or the headlights. You wouldnt think they would popup if only the parking lights are on though.
Or are you talking about the continous runnin?
Old Jun 17, 2005 | 03:52 PM
moparman's Avatar
It's probably the gear in the motor. Search for "headlight fix".
Old Jun 18, 2005 | 12:15 AM
BacardiTA's Avatar
Motor runs and makes grinding noise, headlights pop-up when only the parking lights are turned on, headlights pop-up when arming the alarm... all symptoms of a stripped gear. I have one too and feel your pain. Good news is there's a cheaper alternative then buying a $200+ motor. These links will tell ya more then ya ever want to know about it and where to buy:
http://www.rodneydickman.com/n113.html
http://www.bfranker.badz28.com/headlightfix/
http://www.bfranker.badz28.com/headl...earinstall.htm
Old Jun 18, 2005 | 09:59 AM
Thanks everybody!
93 RedBird
Nov 15, 2015 08:24 AM
Mikes 1994 z28
Oct 10, 2015 07:55 AM
Greg88
Sep 20, 2015 07:14 PM
Daluchman1974
Sep 11, 2015 06:12 AM
jackpawt883
Sep 10, 2015 08:53 PM
