bonecrusher
06-15-2005, 10:49 PM
1993 GMC Typhoon
black on black
100k miles
AWD
4.3 V6 turbocharged
leather
pw,pl,ps
power driver seat
ac
abs
roof rack
cd player
cruise control
REPAIRS!:
5/24/02 thermostat $10.81,
5/24/02 Dash woodgrain kit $51.00,
5/24/02 door lock service(keys made) $36.00,
5/24/02 engine gaskets/sensors $294.55,
6/3/02 Comp cams #412 grind camshaft $260.00,
6/3/02 powdercoat intake and engine brackets(silver) $75.00,
6/6/02 purchase and rework L35 heads with 2.02 and 1.6 valves and springs good to .600 lift $440.00,
7/14/02 edelbrock dual timing chain/gears $82.66,
8/2/02 Crane rocker arm studs/chrome valve covers $77.21,
8/21/02 4 pc floor mat set $46.00,
8/30/02 water pump/gaskets $ 62.50,
9/1/02 front driveshaft $500.00,
9/5/02 radiator hoses $11.12,
10/25/02 comp cams roller rockers $359.32,
12/4/02 glove box door and lamp $49.32
5/27/03 sent stereo to Dr. Don's for repair(factory CD) $162.00,
7/8/03 had oil pan gasket replaced $492.00,
7/11/03 replaced windshield(free),
8/14/03 I sent to hi-tech repair center to figure it out, turns out fuel pump was bad, had a/c converted to R-134a(hoses and accumulator replaced, injectors cleaned, door hinge replaced $888.12.,
8/15/03 new tires and wheels(17 x 8, 245/45ZR17) $1130.25.,
Next was the fuel pump strainer/filter $350.60.,
Wiper plades/driver power window motor $70.85.,
9/05/03 ball joints/alignment $631.06.
9/15/03 we found it had a regular computer and prom so it was replaced $319.58.,
9/26/03 hood bumpers replaced $6.05.,
1/21/04 flowmaster $116.55,
1/28/04 hi-beam switch $282.52.,
1/31/04 fuel pump sender/dampner-pulsator #314.39.,
1/30/04 replaced a/c compressor, serp belt, repair power seat $585.21., 2/5/04 right front axel $75,
2/5/04 installation for axel $78.54.,
2/13/04 rear hatch window struts $35.98.,
11/23/04 tailgate handle $28.06.,
11/25/04 replace plugs $102.38,
1/7/05 starter $78.00, repair purple wire to starter, ign. switch $236.59, 3/11/05 plugs, wires, water pump(again) idler pulley $439.84.
I have receipts for all repairs listed here
images here
http://img.photobucket.com/albums/v676/rollinlarge2700/th_typhoonfrontseat.bmp
http://img.photobucket.com/albums/v676/rollinlarge2700/th_typhoonfront.bmp
http://img.photobucket.com/albums/v676/rollinlarge2700/th_typhoonengine.bmp
http://img.photobucket.com/albums/v676/rollinlarge2700/th_typhoondash.bmp
http://img.photobucket.com/albums/v676/rollinlarge2700/th_typhoonbackseat.bmp
http://img.photobucket.com/albums/v676/rollinlarge2700/th_typhoonback.bmp
black on black
100k miles
AWD
4.3 V6 turbocharged
leather
pw,pl,ps
power driver seat
ac
abs
roof rack
cd player
cruise control
REPAIRS!:
images here
