Tranny is jumping
Old Jun 14, 2005 | 11:11 AM
ddj19852003's Avatar
Tranny is jumping
Only in low gear if i get on the gas pedal relatively hard lets say at about 2000 rpm my tranney will jump or something in it knocks you can feel it right in the center console. I was thinking that maybe there was a mount or something broken. On the freeway or jus once the car shifts out of 1st gear everyhting is fine.
Old Jun 14, 2005 | 11:14 AM
sabre81's Avatar
Re: Tranny is jumping
sounds like the tranny mount to me.
Old Jun 14, 2005 | 11:20 AM
madwolf's Avatar
Yep, tranny mount.
Old Jun 14, 2005 | 11:43 AM
what am i looking at to fix the tranny mount, or is it somethen i could do myself?
Old Jun 14, 2005 | 11:47 AM
madwolf's Avatar
You can do it yourself. Very easy.
Get the car on ramps or jack it up and support the transmission with another jack or anything that works for you. Then remove the crossmember. (4 bolts, I think 14mm and the middle transmission mount nut)
The mount is mounted with 2 bolts. Take those out and install the new one in. Repeat the procedure in reverse order for assembly. Should take 30 minutes at most, maybe one-two hours for someone who has never touched a car before.
Old Jun 14, 2005 | 12:12 PM
LUDA0840's Avatar
get the poly mount it lasts longer!!!
Old Jun 14, 2005 | 12:14 PM
sabre81's Avatar
I installed the enegy susp poly mount on my auto and it was ridiculous. Felt like i was driving with all 4 wheels wobbling. I stuck in a stock replacement instead. I wonder if the t56 is any different... hmmm
Mikes 1994 z28
Oct 10, 2015 07:55 AM
Bxlt1
Sep 29, 2015 03:18 PM
drt
Sep 27, 2015 04:39 PM
z28newbie
Sep 9, 2015 10:26 AM
