I need help
J.D. Tweak
06-14-2005, 11:29 AM
I was hoping someone could help a girl out. I have an 84 Camero used to be a v6 but is now a 305 4 barrel. I have major steering issues but there is nothing wrong with the tire rods or the ball joints or any steering components. Could the Strut cause the car to pull badly? That's the only thing I could tell is loose and has moved other than the fact that the tire is now toed out from hitting the sidewalk due to the original problem. Any info would be appreciated.
Compstall
06-14-2005, 02:29 PM
If you nailed a curb, you could have also bent the control arm, causing your pull.
