Clay bar and interior cleaning...
Old Oct 19, 2002 | 04:22 AM
Greasepunk's Avatar
Ok stupid question, how do u use a clay bar ( I just found out about these, guess I'm livin in the stone(d) age)?
Whats a good product to use to clean the plastic interior molding? Mine is REALLY dirty from the guy who had it before me.
Old Oct 19, 2002 | 09:36 AM
catsnet's Avatar
no one can explane it better then a makers
How you should use Z-18 ClayBar?
First you should thoroughly wash the vehicle to make sure that there is no dirt or debris on the paint finish. Although Z-18 ClayBar is not abrasive to the paint finish, if dirt or debris is present on the paint finish, scratches could result when Z-18 ClayBar is rubbed over a dirty surface. Using a dishwashing detergent such as Liquid Dawn diluted with water will make sure
that the vehicle is free from grease, wax and oily film. (Mix 1 ounce of Liquid Dawn to 2.5 gallons of water for an effective cleaning solution)
Z-18 ClayBar should never be used on a hot surface or in direct sunlight. Using on a hot surface could cause Z-18 ClayBar to stick or "track" on the finish, however this can be removed by simply re-lubricating the surface and rubbing Z-18 ClayBar over the area again.
Z-18 ClayBar is designed to be used with a lubricant. The lubricant creates a "slick" surface for Z-18 ClayBar to glide across. In a spray bottle, mix ½ a cap of Z-7 Car Wash to 16 ounces of water for a lubricant. (You can also mix Z-7 Car Wash in a bucked and lubricate the section with a sponge.)
Lubricate a small section of the vehicle to be cleaned (approximately a 3-ft x 3-ft area). Using adequate pressure, begin rubbing Z-18 ClayBar over the lubricated section to remove contaminants. You can actually feel the contaminants being removed and as the section becomes smooth, simply wipe the area with a 100% cotton towel and continue in small sections until the entire vehicle is complete.
As one side of Z-18 ClayBar becomes soiled, simply flip to the other clean side. After both sides have been used, pull, stretch and refold Z-18 ClayBar to expose a fresh clean side. When pulling, stretching and folding no longer exposes a clean side, discard and use a new piece. Note: Occasionally inspect Z-18 ClayBar to make sure there is no heavy dirt or debris present.
Re-wash the entire vehicle with Z-7 Car Wash if you are planning on applying Z-1, Z-2 or Z-5 immediately after the Clay Cleaning Process.
**Important note: Avoid reusing Z-18 ClayBar if it has been dropped on the ground. If dropped on the ground it may pick up dirt, or other debris that can cause serious scratches to the paint finish.
http://www.zainobros.com/
Do not expect the miracle from this stuff. It's a good product and all but it will not fix the all the tart spots from last years bugs.
On the other hand it worked realy well on my wifes yellow beetle. It had all this rusting spots in the paint (the size of the needle pin) which Zaino Bar cleaned out with no effort at all.
For the interier I use Windex and Armorall on top. I never let it be very dirty though.
Old Oct 19, 2002 | 06:19 PM
AW/whiteZ-28's Avatar
On you interior if its like really filthy with gummy crap on it get a wet towel and some ajax and scrub away then armourall (sp?) over it if it isnt that dirty just wipe it down with a damp cloth
and spray some armourall on ur damp cloth and wipe
the only thing i would say other than this is if you dont need armourall dont use it because once ypou apply it you have to keep putting it on over and over
Hope this makes sense
Old Oct 21, 2002 | 08:59 AM
Brent94Z's Avatar
Super Moderator
I'll move this to the Show and Shine forum...
Old Oct 21, 2002 | 09:31 AM
MikeLS's Avatar
Smile
Clay bars.... http://store.yahoo.com/classic-motor...laybartor.html
http://store.yahoo.com/classic-motor...painconov.html
http://www.carforums.com/auto_help/p...t_clay_bar.php
http://www.zainobros.com/files/z18.htm
http://www.moderncarcare.com/Articles/221deta1.html
Happy reading!
Personally, I'd recommend the Zaino bars. It's my favorite as far as clay makes. For local products to try, go with Mother's or Clay Magic or 3M. I like Clay Magic for local. Basically, clay pulls out harmful embedded particulates in the paint, leaving an ultra smooth finish that's ready for polishing or waxing. It is not meant for removing swirls, oxidation, etc...
For your interior: Meguiar's Heavy Duty Vinyl Cleaner for $8. http://www.meguiars.com/product_show...cfm?SrcLine=PI Follow with a good dressing like 303, Vinylex, or even Zaino Z10.
Old Oct 21, 2002 | 04:23 PM
Crutt82's Avatar
Will using a clay bar clean road paint from the car?
Old Oct 21, 2002 | 06:23 PM
Kevin V 2002 SS's Avatar
I've removed road paint with the clay bar before.
Old Oct 22, 2002 | 03:44 PM
Greasepunk's Avatar
Can you use one of these clay bars on the interior plastics also? To maybe add a little more shine or something or has anyone even ever tried it?
Old Oct 22, 2002 | 06:56 PM
MikeLS's Avatar
No, you don't want to use clay on the interior, plastics, or rubberized parts. It could possibly marr their appearance and will most likely make a huge mess. Clay is strictly for paint, glass, and other metals like wheels...
RUENUF
Mar 13, 2016 03:37 PM
Quickss96
Jan 29, 2016 05:56 PM
Henson071
Sep 18, 2015 04:01 PM
scottcba1
Sep 8, 2015 09:52 AM
Aug 5, 2015 08:35 AM
