4SFEDZ
06-06-2005, 02:13 PM
can you just stick them up there then weld them or do you have to do any type of weighting or anything special?
subframe install ???4SFEDZ 06-06-2005, 02:13 PM can you just stick them up there then weld them or do you have to do any type of weighting or anything special? Z28Nut 06-06-2005, 08:22 PM You want the car as level as possible with it's weight on the wheels. A chassis lift can twist the the car slightly then the welded connectors will try to keep this twist in it. A drive on lift would be best. CreatiVe2 06-10-2005, 02:28 PM or drive up on ramps, but that might be bad if you are welding.. heh )2overt SS 06-13-2005, 08:22 PM I'm also interested in on how to install them. I don't want to pay a shop to do what I can myself (weld) but unfortunately.. I don't have access to a drive on lift (onyl chassis) How else can you do this? WSUFlyer 06-14-2005, 12:01 AM I'm planning to install some using a chassis lift, but..... We're going to let the car down onto floor jacks (the 5-6ft tall ones)...one under each front lower control arm, and two under the rearend. Obviously the main chassis lift will be only inches from the spots it should be at in case something goes wrong and it shifts. Sounds dangerous, and might end up not doing it if i'm not comfortable at the time. Will let ya know. ryan transambill 06-14-2005, 03:16 AM Done a set a couple days ago. You can do it on jack stands. One under each A arm and one under each end of the axel. CreatiVe2 06-14-2005, 04:45 PM that sounds sturdy enough, im thinking about 2 jackstands under the rear axels withthe front on ramps... did that for header install, worked fine transambill 06-14-2005, 05:11 PM that sounds sturdy enough, im thinking about 2 jackstands under the rear axels withthe front on ramps... did that for header install, worked fine That will work fine. As mentioned the suspension just needs to be loaded like it is when the cars setting on all 4 wheels. WestCoast96Z28 06-15-2005, 03:50 PM Not sure what brand you're installing, but my BMRs are a little close to the fuel lines on the driver side...just be careful. Also, if they're painted, you'll need to grind off the paint to get a good weld joint. CamaroSS30thAnn 06-15-2005, 05:41 PM Not sure what brand you're installing, but my BMRs are a little close to the fuel lines on the driver side...just be careful. Also, if they're painted, you'll need to grind off the paint to get a good weld joint. this is true, i had mine done on a chasis lift , really no problem here, i didnt know that u had to have weight on the wheels , i guess i lucked out the car is level | ||
