chevy1963
06-06-2005, 09:46 AM
Just scanned my car and I'm getting these codes. I just did obd1 conversion.
Malf 97 4000 ppm vsss circuit fault
Malf 82 Shift A Soloniod Fault
This is the discription for code 82 1-2 Shift Solenoid Circuit Fault "1-2 shift solenoid is commanded ON by PCM but circuit voltage is high for two seconds
OR
1-2 shift solenoid is commanded OFF by PCM but circuit voltage is low for two seconds" "*Maximum line pressure
*Second or third gear only
OR
*First and fourth gears only"
How do you fix this? and the other code?
OR
OR
