LT1 POWR
06-06-2005, 12:58 AM
What can i do to "hook up".
Best traction mods.LT1 POWR 06-06-2005, 12:58 AM What can i do to "hook up". Bow94z 06-06-2005, 01:02 AM tires...lower control arms/reloaction brackets, i think different rear springs/shocks will also do the trick lt4 fd 06-06-2005, 01:04 AM First and foremost I think would be tires, Ide imagine that a great tire with a stock suspension would do WAY more than a crappy or even average tire with any amount of suspension mods.... Black_Z28 06-06-2005, 01:05 AM First and foremost I think would be tires, Ide imagine that a great tire with a stock suspension would do WAY more than a crappy or even average tire with any amount of suspension mods.... Yep, tires are your most important link to traction. All traction will be lost with crappy tires. simple 06-06-2005, 01:07 AM airbag is a cheap and affective mod in the pass side rear spring! LT1 POWR 06-06-2005, 01:57 AM Would it be better to buy a package like this one http://www.lmperformance.com/4168/2.html or like these http://www.lmperformance.com/1825/2.html http://www.lmperformance.com/1828/2.html. Also what size drag tire and rim would you recomend. 94'_Z28 06-06-2005, 02:13 AM http://www.lmperformance.com/1825/2.html and some bigger rims/tires would do the trick. First should be the tires, then the suspension parts though. Black_Z28 06-06-2005, 02:18 AM I for one am not a big fan of the BMR torque arm. I like the Spohn because it bolts to the cross member instead of the tranny. The crossmember is just a stronger point, and won't put any stress on the tranny. 1racerdude 06-06-2005, 03:54 AM 1-- frame connectors (Global West) 2-- Sphon TA 3-- coil over's in front 4-- adjustable rear shocks 5-- LCA's with spherical end's of some type 6-- tire's 7-- remove front sway bar 8--remove front bumper 9--2-3* pinion angle 10-- the right air bag set at 20-25lbs with rubber pads on top and bottom (a little work) 11-remove factory rubber spacers from rear on top of springs. 12-- keep air pressure in DR's above 22PSI. simple 06-06-2005, 06:09 PM LR, this is the 2nd time i've seen you recommend the GW SFC's over some others. what is your preference with those? 1racerdude 06-06-2005, 06:20 PM LR, this is the 2nd time i've seen you recommend the GW SFC's over some others. what is your preference with those? They FIT. ya don't see them under the car and they are good material unlike some other's.With them ya can set your car on three jack stand on the corners. | ||
