sabre81
06-04-2005, 05:54 PM
According to http://www.afrashteh.com/tranny_pics/T56.htm, i need an exhaust mount for the swap? where? and what? im confused.
what the hell is an exhaust mount doing here..sabre81 06-04-2005, 05:54 PM According to http://www.afrashteh.com/tranny_pics/T56.htm, i need an exhaust mount for the swap? where? and what? im confused. Injuneer 06-05-2005, 01:30 AM As I recall, there's a bracket to support the cat, bolted to the tranny tailshaft housing. Its held on by the same bolt that holds the TA bushing. At least there was one on my T56 with single cat. Check out the exploded view on Shoebox's Tech Pages, part #31 may be the one. http://shbox.com/1/exhaust_system.jpg Z28Nut 06-05-2005, 09:21 AM Yeah, my A4 single (former) cat car has a bracket to hold up the rear of the cat - or ORP - attatched opposite the torque arm bushing mount. So I imagine the T56 needs one, too, to support the cat and front of the catback. GMH94Z28 06-05-2005, 03:42 PM Do you have to use the exhaust hanger? When i did the swap from a4 to t56 i didnt have one and i have a straight pipe where the cat used to be. Thanks Z28Nut 06-05-2005, 03:51 PM The exhaust is held up by the manifolds/headers, trans bracket, and muffler hangers. Without the trans bracket that's a lot of pipe just to be held up at each end. The connections - unless everything is welded - are going to have too much stress on them and will sag and eventually leak. sabre81 06-05-2005, 04:24 PM what is that black plate in the middle here.... http://www.thirdgenparts.com/92LT1RS/T563.JPG Lisa33 06-05-2005, 04:58 PM justy skip it, havent got anything else than the 2 frame mounth fasterners on my 4" exhaust, no problems at all... http://home.koping.net/u3243a/vinter%2004-05/DSC02413.JPG Z28Nut 06-05-2005, 09:20 PM what is that black plate in the middle here.... http://www.thirdgenparts.com/92LT1RS/T563.JPG Basically a dust sheild for the bottom front of the bellhousing. The hole in it is for the starter nose. | ||
