onthemat
06-04-2005, 04:02 PM
What it says above.
Will a '98-'02 axle shaft fit a '95?onthemat 06-04-2005, 04:02 PM What it says above. Ryan94ZA4 06-04-2005, 06:34 PM Yes, it will. Only true difference between the 2 is the center hub on the 93-7 has a larger center. If you run a 93-7 axle with a 98-up factory wheel, you have to enlarge the center hole by about 1/32". Ryan onthemat 06-04-2005, 08:10 PM Thanks man. Maybe now I can keep my axle seal from leaking. | ||
