New Steering rack and tierods....now steering feels too tight
Knowklew
06-03-2005, 07:02 PM
Well i had my steering rack and tierods replaced under GMPP warranty. The steering now actually takes a good amount of effort to turn the wheel. I admit there is no play in the wheel, at all, but it almost feels like its just too tight. I had a tech drive it with me to make sure i wasnt crazy and he told me it was normal.
So would i be safe to assume that the new rack needs to be broke in before it will loosen up a bit or am i just stuck with it the way it is? Compared to before, it's like going from a cheapo econobox to a ferrari, there is that much difference.
Edit: The tech told me he readjusted the toe after he installed the tierods.
Z28Nut
06-04-2005, 01:58 AM
It's probably fine but with both the rack and tie rods being bad, you're used to it being very loose. You'll get used to it pretty quick.
OBE1 95Z28
06-05-2005, 02:58 PM
I rebuilt my entire front end suspension (upper and lower bushings, inner/outer tie rods, new steering rack, rag joint eliminator, new upper/lower ball joints) and my steering is easier than before with no slop in the wheel.
Knowklew
06-05-2005, 04:13 PM
the main problem i am having is that it is easier to turn the wheel right than it is to turn it left. This leads me to believe that something isnt right
Bow94z
06-05-2005, 04:42 PM
hmm, is it a new GM rack? how much was it? i know you said it was covered under warranty but how much was it?
Knowklew
06-05-2005, 04:46 PM
Warranty........I paid ZERO.
All GM parts.
Part numbers from my receipt:
88910454
88991056
Knowklew
06-05-2005, 10:19 PM
night crew
