SLP SFC with Spohn Body Torque Arm
CreatiVe2
06-03-2005, 03:00 PM
Is this do-able? from what i understand about the 2 parts, is that the SLP bolt on SFC, bolts to the tunnel brace support and the spohn T/A w/body mount, mounts there also? i may be wrong abotu the T/A. but does this sound right? will the SFC's get in the way of the torque arm?
simple
06-04-2005, 03:19 PM
if the SFC's bolt too the tunnel brace mounts, yes they will be in the way
why not just get a set of tubular SFC's?
the triangulated SFC's seem too be a PITA when it comes too adding aftermarket parts and the difference between the 2 different styles is going too be negligible IMO
1racerdude
06-04-2005, 09:43 PM
Global West makes a nice set for your car.
CreatiVe2
06-05-2005, 02:49 PM
do you have a link to the global west?
1racerdude
06-05-2005, 02:52 PM
http://www.globalwest.net/
CreatiVe2
06-05-2005, 02:57 PM
lol.. duh, thx!
john35thss
06-05-2005, 07:49 PM
Have both on my car and my brother in law's car, works great and bolts up fine just need to use studs instead of bolts.
John
LiT1_up
06-05-2005, 09:45 PM
Have them both on my car also with no problems.
CreatiVe2
06-06-2005, 11:47 AM
ok, i see how with studs they could work... ARP? and what size... because when i get the SFC's in im goign to want to go LCA and TA right away... thx for help
ss125
07-01-2006, 10:52 PM
John
I put the Spohn TA on lastweek end. How did you put this on with the SLP sfc's. The instructions say to put the crossover (g-brace) under the sfc's. There is no way mine will go under there and get it bolted up. The tubing prevents the g-brace from going under the sfc's. So how did you do it?
Kevin Blown 95 TA
07-03-2006, 03:25 PM
I stuck mine over the SFC flanges and it's fine that way.
NOSCaMaRo
07-03-2006, 05:31 PM
UMI Performance recommended the 3-Point SFC's to me when purchasing the tunnel mounted torque arm. The SFC's take the stress instead of the floor board, its a pretty sick set-up. Check out the picture below, give UMI a call and I am sure they can set you up with a price on both
http://www.umiperformance.com/images/2004b.jpg
firebirdStud
07-03-2006, 11:13 PM
I have slp triangulated sub frame connectors, and the spohn torque arm. I put the torque arm over the sub frames. Works great. I just bought longer bolts. No studs needed. I have yet to run into any problems doing it this way. Go for it, it stiffens that bizzich right up! I love it!
