jorgez28
06-02-2005, 05:52 PM
I Have a 2000 formula with the 10 speaker monsoon and have blown speakers on the sail panel I need to know what brand of speakers should I get to replace them?
which speakersjorgez28 06-02-2005, 05:52 PM I Have a 2000 formula with the 10 speaker monsoon and have blown speakers on the sail panel I need to know what brand of speakers should I get to replace them? PaulN64 06-06-2005, 04:16 AM with the moonson system, you'll have to buy the stock one unless you plan on changing your entire stereo system. If I remember correctly, the Monsoon is like the Bose system and you have to replace everything or go back to stock. jorgez28 06-06-2005, 07:08 PM It's the stock system that came with the car I just can't get aftermarket speakers and hook them up?????? :confused: 97FormulaWS-6 06-06-2005, 08:23 PM Nope, the Monsoon and Bose systems are all "odd" and require either complete replacement or stock only replacement. The impedences of the Monsoon amps/speakers are not the normal 4 ohms, I believe they are all 2 ohm speakers; I'm not 100% sure of this, but basically if you just replace the speakers with aftermarket, they will sound like crap. It's a gut-n-replace type stock system. PaulN64 06-08-2005, 03:36 AM It's the stock system that came with the car I just can't get aftermarket speakers and hook them up?????? :confused: I think your stock speakers are 1ohm speakers. If you get an aftemarket one, they are usually 4ohms. The speakers won't sound as loud. Best thing to do is to just rip out the entire system and put a new one in unless you plan on replacing it with stock jorgez28 06-14-2005, 02:22 PM So where can i get stock speakers??? PaulN64 06-15-2005, 01:11 AM you can go to the dealership or ebay. I don't know any online sites that sell stock speakers. jorgez28 06-17-2005, 07:01 PM well I took out the sail panel speaker and it has 4oms stamped on the back of it so can I use a 4oms speaker? :confused: matt65 06-17-2005, 08:24 PM well I took out the sail panel speaker and it has 4oms stamped on the back of it so can I use a 4oms speaker? I would. PaulN64 06-18-2005, 02:13 AM well I took out the sail panel speaker and it has 4oms stamped on the back of it so can I use a 4oms speaker? :confused: you'll be able to use any 4ohm speaker although it may not be as loud as the stock speakers since most aftermarket speakers are made to handle more power than the stock system produces | ||
