Octane
stmz28
05-30-2005, 08:18 PM
what is the highest octane you can ran with a stock engine.
1racerdude
05-30-2005, 08:52 PM
116
cwatts23
05-31-2005, 12:57 AM
why would you want to run 116 octane on a stock engine?
1racerdude
05-31-2005, 01:05 AM
Ya asked what was the most ya could run?????
The more octane probably the slower it will run.
92 should be about right with a tune to take advantage of it.
Greed4Speed
05-31-2005, 10:58 PM
Highest you SHOULD run is 93. Anything more is wasted $ and excess emissions.
mustang5.0
06-01-2005, 09:24 AM
Sun Ultra 94.
The car runs good on it. I run 94 in my bike and can feel a better
pull.
My Harley friends don't use Exxon becouse of the dye in the gas. It
gums up the injectors. So I don't use Exxon in the Camaro either...
Jim :cool:
Jay3274bbl
06-01-2005, 04:03 PM
I think 116 is leaded and if you put it in your car it will mess up your O2's. I do know they make 100 in an unleaded version, but unless you are running high compression I would stick with 93.
Greed4Speed
06-01-2005, 11:14 PM
Leaded will ruin the cats also.
danksontl
06-02-2005, 05:22 PM
93, because I have not increased my engine's compression ratio or added a power adder. With no such reason to increase the risk of detonation, you would not need anything higher than 93 in a properly functioning engine. Higher octane is more $$$$, don't waste it on gas when you can spend it on mods later. ;)
