Bayer-Z28
05-29-2005, 02:48 PM
I can't find my install manual, and this computer sux, can't open anything.
What's the TQ spec for the SLP LT's on a 2000 LS1???? Header to head bolts..
BirchMan98z
05-30-2005, 07:13 AM
Around 15-20 ft/lbs will do it. Really there's no torque spec for the header bolts, just hand tighten them, and use a ratchet to make them as tight as you feel is safe.
Bayer-Z28
06-01-2005, 12:10 PM
Well, I found them. I was pulled off the project for a while. I went up to my cousin's and looked it up. It was 11ft/lbs on the first phase and 18ft/lbs on the final. It took me 14 hours to do the install. The pass side was a major PITA!!!! I had to trim the K-member and loosten the trans mount, move everything around just to get this one primary to slip in!
