cam and head question
Green98
05-28-2005, 04:53 PM
roughly how much for a cam and head install, or just the cam install on a 98 ls1
teke184
05-28-2005, 11:57 PM
cost from my local mechanic:
new parts:
lifters
pushrods
oil pump (ls6)
double roller timing chain
TSP torquer cam
all gaskets and bolts
included a dyno tune - $2300
now i already had decent valve springs on there, so he didn't have to do those.
and also...if only a cam swap you don't need to pull the heads...i had him change lifters (requires you to pull the heads on an LS1). so that was more $$ for gaskets and headbolts and labor.
i think his cam only swap with dyno was $1800
Green98
05-29-2005, 01:55 AM
thanks
Schmidt519
05-29-2005, 07:49 PM
I'm getting a cam installed on June 7th
Parts $2300
Cam
LS6 Intake Manifold
Underdrive Pulley
Oil Pump
Double Roller Timing Chain
Matched Valvetrain components
Fuel Injectors
Spark Plugs
Cam install $450
Tune and other labor $400
Total: $3150
teke184
05-30-2005, 09:08 PM
why do you need newinjectors?
stock are fine for a pretty good amount of hp
Schmidt519
05-30-2005, 09:48 PM
The shop who is installing my cam recommended the injectors, said i would eventually need them anyway, while they were there they might as well put new injectors and plugs in.
QuickSilver02
05-30-2005, 10:08 PM
Heads - $1500
Cam - $300
Gaskets, bolts, etc. - $200
Dyno Tune - $400
Putting it all in yourself and having it run - Priceless :D
teke184
05-31-2005, 07:39 AM
i guess if you got the extra money, may as well do them since you can get them adjusted for during the tune.
but i'm running a 233 cam and my injectors seem to be doing just fine. right now i can think of better ways to use $500
