Purge vent tube question
Old May 27, 2005 | 11:46 PM
Cmr0z28's Avatar
Do I need to drill a hole for the vent tube to go through the cowl?
Also, how do you bend the vent tube without collapsing it?
Anyone have pics of theirs?
Thanks!!
Old May 28, 2005 | 06:46 PM
Wishmaster's Avatar
Re: Purge vent tube question
Hey I can help ya there. I drilled a hole in the center of my cowl. THe tubing is pretty flexible although I did got buy a tube bender for about $6 at NAPA>......I used 3/16ths brake line also from NAPA which fits right into the purge selonoid hole.
The tubing will collapse if you bend it to much by hand but with the bender its works fine.
Old May 28, 2005 | 07:17 PM
Cmr0z28's Avatar
Ok, how do I secure the line?
Do I still have to use a compression fitting?
Thank you very much for being specific
I'll take a trip to NAPA tomorrow.
Old May 28, 2005 | 11:41 PM
Wishmaster's Avatar
Yeah you should be able to use the compressor fitting that came with your kit...or NAPA will have them too. AS far as securing the line, that all depends on where you put it and how you run it...On my from the Purge unit and into the Cowl where the winshield wipers are, it kinda just held itself there...
HectorM52
Jul 30, 2017 11:46 AM
alphaauto
Jan 23, 2015 07:42 AM
CARiD
Jan 14, 2015 04:00 AM
Red_94Formula
Parts Wanted
Dec 6, 2014 11:07 PM
Jul 4, 2005 05:00 PM
