chris96camaro
05-27-2005, 10:10 PM
I am looking into getting a diamond audio tdx 12" sub. I currently have one jl 12w6v2 running off about 411 watts. how much of a difference will there be in the amount of spl that i am getting now to the amount of spl the diamond will produce?
94'_Z28
05-28-2005, 12:30 AM
Are you getting a bigger amp or anything? If not I would stick with the set up you got, cuz there will be no real noticeable difference (if any) in SPL. There are three ways to get a noticeable difference in SPL. First would be to go with a custom ported box, if built right you will get up to a 3db gain. Second would be to double your power (wouldn't recommend with that sub) and you will get a 3db gain. Last would be to add another sub, which will get you a 3db gain as well.
chris96camaro
05-28-2005, 10:29 AM
I will be getting a kenwood amp that runs 900 rms at 1 and 2 ohms. Thats more than double the wattage going to the w6v2.
Rashiki
05-29-2005, 09:05 AM
Go with the Diamond. Not only will it handle more power, but it's got an efficiency rating of 91db. The JL has a lower power handling, and also a much lower efficiency rating of 85.9db.
The lower the efficiency rating, the more power it takes to get to a certain spl. If your driver is more efficient, the less power it will take.
Diamond, hands down.
