JaWdRoPn
05-25-2005, 04:08 PM
Hey guys I just replaced my ac-compressor with a brand new AC-Delco Compressor and the computer shuts off the compressor after it has been running for about 2-3 min. If you unplug the battery and reset the computer it will turn on again but only for 2-3 min. Anyone have any idea why?
OBE1 95Z28
05-25-2005, 04:22 PM
The computer monitors A/C pressure; if your pressure in the lines is too low it will shut off.
JaWdRoPn
05-25-2005, 04:55 PM
Meaning I have a leak right? What are some good places to look for a A/C leak?
JaWdRoPn
05-25-2005, 05:05 PM
My problem started with my A/C not working, no cold air. I also had a DTC for the A/C clutch not engaging, I figured it was the A/C clutch, changed the compressor and its the same problem.
OBE1 95Z28
05-25-2005, 11:16 PM
My friend's 95 has a slow leak through the AC schrader valve. I'm sure a shop could pressure test the system and find the leak.
Johnny-Z-Man
05-26-2005, 01:44 PM
Maybe you overcharged the system!
Did you add Ester Oil into the new compressor before installing it?
NJSPEEDER24
05-26-2005, 04:22 PM
Do you mean PAG oil?
