Zero_to_69
05-23-2005, 08:56 PM
There is a slight ticking to the rockers which I believe to be normal now.
Some say aftermarket rollers tend to be noisey. I set my pre-load to 0.021" (which includes 0.006" lash) using a dial.
What I don't find to be normal is the lack of oiling to the rocker arms.
There is nothing splashing out. The oil pressure reads 40 PSI (at the manifold sender port) at 2000 RPM.
Should I be seeing oil spraying from the rocker oiling holes? The engine
is cold, only running for about 2 minutes at this time. I'm a little concerned.
Here's a video of the rockers in action:
http://gmthunder.com/tino/oil_rockers.mpg
Additional info:
When I was setting my pre-load, I noticed the lifter seat did not move down.
I figured they were still pumped up. After rotating the engine by hand several
times, the lifter seat still remained solid. I was expecting the lifters to bleed
down?
After cycling the engine a few times. I checked the lash. I still could not
depress the lifter seat, however the rocker tips were tight on the valve stem
and the adjusting nuts and set screws were tight. I could not stick a 0.006"
feeler between the rocker tip and valve stem at TDC.
Thanks for your time.
Additional info:
down?
