garage sale
Leroy808
05-23-2005, 10:49 AM
Here it goes:
1 lt1 engine block
i got this block thinking i would build it up but changed my mind. it is in good shape. only thing that comes with it is the main caps. the block has not been bored, it might need to be but i never got it to a shop to check.
$125 obo
1 350 engine dismantled
it is a GM high performance engine you can find it in Summit to check specs on it. the only difference beween mine and the one in Summit is mine was the older version that didnt come with the vortec heads. it was speced to 300 hp. it is dismantled because 2 of the pistons broke. i still have them so if anyone wonts i can try to get some pics up of them. there is no visible damage to the cylender walls but boreing it might not be a bad idea.
the block comes with:
oil pan
crank
connecting rods
pistons (broken but you can have them if you want, im not charging anything for them)
timing chain cover
cam (no lifters or pushrods, not a roller cam)
heads (i dont know the specs on them but i will do some looking), heads are built with stock set up
oil pump
summit hi flow water pump
this block has the bolt holes for one of those spider-like atachments to hold in roller lifters, the engine just didnt come with the roller cam. this is the engine that i had in my car, 1977 camaro, with a 700r4 trans stockish TPI and a non posi 256 rear end (yuk) and it ran low 14's.
$325 obo
1 remote thermostat housing
used in the lt1 intake swap
$40 obo
brand new summit hi flow oil pump
$35
1 87 TPI plenum
$25 obo
1 engine hoist (availible soon, i still need to use it to put my new engine in, but that will be done within the next week or so)
$150 obo
thats all i can think of right now. im sure there will be more as i continue to clean out the garage. i live in Casselberry, which is outside orlando. you can email me @ Jon.nellson@gmail.com. if you would like to give me a call i will be happy to email you my #.
thanx,
Jon
DarthIROC
05-24-2005, 06:44 AM
Mail Sent
Leroy808
06-07-2005, 07:02 PM
bump
MyTMous
06-11-2005, 03:15 AM
You keeping the 700R4?
Fbodyboy1994
06-11-2005, 09:30 AM
i'll give u 125 for the hoist,and i'll pick it up
Leroy808
06-14-2005, 11:13 AM
no im keeping the 700r4 but Fbodybot, the hoise is yours.... send me an e-mail and well work out details... Jon.Nellson@gmail.com
